Old 08-01-2016, 09:56 AM   #60 (permalink)
ThatDudeOrion
So much awesomeness in this thread. I've got a similar project going, but haven't really documented or started a build thread.
I have a 95 trans am with the same LT1 engine in it that I use to commute almost 300 miles daily. I've done some very minor aero stuff, weight reduction, engine mods, and a trans swap from 4l60e to T56, so I've got a 0.5 6th gear in the trans and the 2.73 rear left over from the auto trans. I'm averaging around 35 mpg over the course of the whole commute with a high of 36.5 mpg, and I don't do any P&G, and I only EOC while going down big hills, trying to keep average speed around 75-80mph. So I think your estimates are spot on for what you'd get with more traditional driving style. One of my biggest wins has been running a laptop with the tuning software $EEHack, I can make fueling changes in real time and approximate a lean cruise which the stock LT1 pcm can't do. You may want to look into this if you haven't already.
The Following User Says Thank You to ThatDudeOrion For This Useful Post:
funkhoss (08-06-2016)
