Old 08-08-2008, 08:15 AM   #12 (permalink)
Gregte
GMC Sonoma - '94 Sonoma
90 day: 36.97 mpg (US)
Originally Posted by rick390 View Post
Speaking of clutches. Just had a new one installed so I thought that would be the end of the shuddering starts. Not so. Unless I am on level ground and very slowly ease the clutch out I still get a bit of the shudders.... WTH.
It definitely shifts from gear to gear better. Does it need adjusting or do I have something loose in the front end causing this?
It may be that it was installed poorly. This happened to me once. The clutch on my 2-ton truck was always very smooth. It finally wore out so I had a new one installed. It shuddered terribly up until the day that I had a new motor installed. Afterwards the clutch was again smooth. Apparent misalignment the first time when it was installed.
