Old 08-07-2016, 10:45 PM   #3 (permalink)
thingstodo
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Hi Paul,
I got the AC Controller to build. But the DC Controller gives me this message when the project opens
Warning: Project "testdc1" appears to have a CPP source file. The project may fail to build if you are using a C compiler.
And YES, it does fail to compile ... but not the way I'd expect?
make -f nbproject/Makefile-default.mk SUBPROJECTS= .build-conf
make[1]: Entering directory 'C:/Project/testdc1.X'
make -f nbproject/Makefile-default.mk dist/default/production/testdc1.X.production.hex
make[2]: Entering directory 'C:/Project/testdc1.X'
make[2]: Leaving directory 'C:/Project/testdc1.X'
nbproject/Makefile-default.mk:84: recipe for target '.build-conf' failed
make[1]: Leaving directory 'C:/Project/testdc1.X'
nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
make[2]: *** No rule to make target 'build/default/production/UART4011.o', needed by 'dist/default/production/testdc1.X.production.hex'. Stop.
make[1]: *** [.build-conf] Error 2
make: *** [.build-impl] Error 2
BUILD FAILED (exit value 2, total time: 564ms)
What did I miss? I've messed around with this for a few hours on and off. I went through some of the MPLab X docs on what to do to get rid of
'no rule to make target ...' but the include files are right, the external definitions are fine ...
And this line
confuses me.
What I did, after installing MPLab X and the XC16 compiler:
- add new project
- Microchip embedded - standalone - next
- select device - dsPIC30F4011 - next
- PICkit 3 - next
- XC16 (v1.26) in default directory - next
- testDC1 in project location C:\Project with only 'set as main project' checked
In the last step I have tried most combinations of check boxes.
Is it something obvious I did wrong? or missed?
Mike
The Following User Says Thank You to thingstodo For This Useful Post:
