FWIW, I went from a 47 tooth rear sprocket to a 37 tooth (I have a 15 tooth front sprocket FYI). It is a significant reduction in rpm for a given vehicle speed.
Now my 4th gear is like what my 6th gear used to be. It took a little getting used to when taking off in first, and when selecting gears for a given situation, but I like it and am getting good mpg results with the setup. It's all instinctive now.
When cruising I am at a lower RPM with more throttle opening (more efficient generally), and if I need the acceleration to get up a hill or something, I can always downshift.
