Decided to go install one on my Metro...
MAYBE 10 minutes (have not hooked up bulb yet) -- MULLET!!! What am I missing on removing the heater control panel? 2 Screws from under at radio, 1 screw for the tiny dash piece.......... do I have to take the main cover from under the column?
The gauge mount clipped under the plastic behind the column like it was meant to go there. No screws required. Have it offset to the right of center... I like to see the spedo,,, but I only need the left. My vision is only impared of 70mph and above.
---Gauge was very fluttery, I pinched off the line to give it a buffer, and now it's as smooth as can be. Hovers around 23 at idle, normal but conservative driving up the road, looks like 10 is the goal. Higher rev shift points means less load on the engine.....
Shifting too soon makes the engine work very hard.
