Old 08-08-2008, 09:39 PM   #14 (permalink)
Raysp30
SaturnSl1 - '00 SL1
90 day: 40.21 mpg (US)
MyPickup - '96 Ranger
CRX HF - '89 CRX HF
90 day: 51.59 mpg (US)
Originally Posted by bbjsw10 View Post
Use the wires on 87a and 30 on your Injector resistor power feed. Will work the same way. I ended up changing mine to this after writing how-to. I believe the injector resistor on your car should be close to brake booster and look like this.
I think I see what you mean. Just cut into the red wire (power feed) and plug those into the relay? Do I still need to use the inline fuse with this setup? Appreciate the help.
