Old 08-08-2008, 11:10 PM   #7 (permalink)
Frank Lee
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
RiseAbove,in the phil knox aerodynamic photo albums,under Book Illustrations,second row from bottom of 1st page,is an illustration of Walter Korff's zero-drag,cooling system design.It's used in race cars,and a good model for ecomodders.---------------------------------------------------------------One thought with respect to rear engine cars,is center-of-gravity,with respect to aerodynamic center of pressure,something critical to a vehicle's directional stability.Conventional wisdom suggests that you always want the center of pressure behind the center of gravity,which yields high speed terminal oversteer.For front-engine cars,especially front-wheel-drive cars( like the Citroen as mentioned),this is especially easy to accomplish.Moving the engine to the rear can introduce terminal understeer at high speed,and as the front of the car yaws downwind,it catches even more air,increasing the yawing moment,with potentially fatal results.--------------------------------------------Modern monster mpg concept cars with rear engines, were lightweight two-strokes,which helped address the weight bias issue,and will probably never see production.Its true that the rear layout can provide an edge with respect to cooling,however,it may not necessitate moving the engine,only the cooling system as done with Ford Probe concepts,or just idealizing the front system to Korff's recommendations.
yer over- and under-steers are ternt around.
Having had several rear-engine vehicles, I can say I like the handling dynamics of them- nice, feather-light and responsive steering, not to mention superior traction. From a strictly utilitarian standpoint, though, it is better to have the trunk in the back, both for super heavy and oversize loads. And they are more sensitive to crosswind gusts.
