Old 09-04-2016, 05:38 PM   #2 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
The electrical system is fussy, stock everything is the only way I could get the turn signals to work, the headlight is also an odd size.
The rims are heavy steel, so if you wanted to shave weight that would be your biggest savings.
Go extreme with the sprockets, at 250lb mine would go 60mph after regearing.
For a while I also ran 10% vegetable oil without any issue and saved that 10% gasoline, 20% reduced performance at high revs.
