Old 09-06-2016, 08:48 PM   #274 (permalink)
Bill the Engineer
Bill the Engineer's Avatar
Originally Posted by darcane View Post
Most Excellent Bill!
That's awesome seeing the Firebird nose on there.... but the picture I left in your quote shows quite a lot of misalignment of the Firebird radiator hole and the Prius radiator. Are you planning some sort of ducting there to help with cooling?
Actually the core support is about an inch too high in that photo. I realized after the bumper was on that I had left the old rubber supports on the bottom that should have come off first. (D'oh!)
And yes, there will be both ducting and bracing between the Prius structure and the Firebird core support, plus the original baffling between the core support and the front bumper assembly.
Bill the Engineer
The Following User Says Thank You to Bill the Engineer For This Useful Post:
aerohead (06-19-2020)
