Old 09-20-2016, 10:15 AM   #11 (permalink)
Wyodaniel
Good taste in both trucks and bikes (see my garage)!
Hah, yours is 3 years newer than mine. I have a tendency to blow through bikes quickly, but this 600 F3 I just can't convince myself to sell, it's too perfect. I love the look, the sound, the performance, and even find it fairly comfortable for long distances (Did a 4 hour ride to Rapid City to buy the truck).
Anyways, here's what I'm thinking right now based on your suggestions in this thread so far:
-Gear ratio change from 3.73. (Should I go for 3.54, or is 3.42 an option here?)
-Remove all emissions control “garbage”. (Not sure if I have anything that even needs to be removed on an '03)
-Confirm no brake drag / leaks, no CAC system leaks, proper alignment
-Front air dam as low as possible
-Open up exhaust and straight pipe
-Bed cover
-Possibly a Smarty JR, if it's worth the $500
The Following User Says Thank You to Wyodaniel For This Useful Post:
slowmover (10-22-2016)
