Old 09-22-2016, 01:39 AM   #21 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
Install a fast response probe EGT.
Run the absolute lowest temp posable to maintain speed. EG. I run 500° f in the flats 600° mild hill 750-800° f for mountain passes @60-65 mph
Wrap the turbo and exhaust manifold to retain more heat energy inside the system instead of cooking everything under the hood. .the wrap has reduced my under hood temps drastically. Reduction of 100° across the bord EG before 1psi=600° f after 1psi =500°f . Much faster spoolas well.
synthetic oil Everything P/S , M. trans , diff.×2, T-case, grease. DO your Preventative Maintenence synthetic mobile 1 appears to have reduced my EGT by 50-75°f EG 70 mph is normally 700-750°f now 600°f and virtually eliminated my cooldown time (from 1-5min to .25-1min to reach 300-350°f ), idle temp reduction of 25-40°f
If you want tall tires go with 255/85R 16(33×10.00R16) my medium 235/85R16 (32×925R16)
Short 215/85R16 (30×850R16) as compaired to a 245/75 R16 (30.5×9.5R16) if your truck is running 18"s just add 2"to the OD
Use the Defrost as little as possible in winter. This setting uses the AC compressor to dehumidify the air before blowing it on cold glass.
Question for the 3rd gen owners .
Can the extra "cleaning "injection event with the exhaust valve open be programmed out of existence?
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
