I'll take/post a picture of it. Its suppose to rain tomorrow. So it might be a day or two before I can post it. But there's a hole stamped in the radiator support for it to get direct air flow. Its on the side of the radiator about half way down when you are looking between the grill and radiator support.
Sucks on your wheel bearing failure. I just replaced mine earlier this year. I had the inners fail which causes a funky vibration at interstate speeds. Which for the record I didn't know the inners could fail without the outers failing at the same time. But it happened.... I'm OCD about these things!
Back story, I had a ford pickup years ago that the passenger front wheel bearings failed while on the highway. It launched the wheel off leaving me to skid to a stop on 3 wheels from 65mph. A bit of a "pucker" moment!
