Old 10-06-2016, 09:39 AM   #20 (permalink)
rmay635703
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
Originally Posted by cowmeat View Post
I ended up getting it for 12 grand.
Well, there's one issue I won't be dealing with! Winter here in central Florida lasts about a week
What is an ambient temp resistor?
12k is pretty typical for a low mile car with premium trim.
Check out GM-volt you just need to look up somms
The sensor tells the car the outside temp which is displayed on the center console.
Below 25 degrees and the motor idles to make heat every few minutes.
Also if you drive lots of 1000 + mile trips like me you will wish you had a 13 volt but in another way your car still has the full underbody aero panels
Lucky
The Following User Says Thank You to rmay635703 For This Useful Post:
aerohead (11-13-2019)
