Can't seem to get it right...
I had a relay from Radioshack that had 4 pins on it, no 87a. I hooked it up by splicing into the red wire on my fuel injector resistor. Once all the wires were in place I tried starting the car and it wouldn't turn over.
I found a different relay that was supposed to have the 87a pin on it, but there was only a stub where the pin should have been, and the packaging on that relay had never been opened.
Is there a 2nd wire I need to splice into to make this work?
