Old 10-21-2016, 03:27 PM   #28 (permalink)
BamZipPow
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
Wink
That's a good score. (Someone was just telling me about the aluminum sheets they use for freeway signs.) That's a nice piece, I'm hoping you can just drill a few holes and not have to cut it up a lot.
I would think diamond plate down would be like hundreds of little vortex generators, all working at cross-purposes to each other, but gently combing the airflow to sooth and relax it.
Besides, face up — nobody could see it.
I've been trying to source some highway signs to work with but I haven't found a source yet.
There will be only one cut to make two pieces fer the rear belly pan (just before the rear axle) and the rear diffuser. Both will be reinforced with aluminum angles and slotted angles. It will be pretty much a straight replacement fer the initial Coroplast setup that I originally started out with.
Dark Aero-The world's first aerodynamic single wheel boat tail!
The Following 2 Users Say Thank You to BamZipPow For This Useful Post:
aerohead (10-22-2016), freebeard (10-21-2016)
