Old 10-24-2016, 06:03 AM   #68 (permalink)
Hank1510
Originally Posted by WyrTwister View Post
I am guessing that you do not have to do that if charging 240 VAC Level 2 .
God bless
Wyr
You're right, only level 1 requires you to enter the amperage every time. It must be some litigation thing. If someone was using 12 amp and moved locations where only 8 amp was available, then they could have electrical problems.
240 volt outlets have different styles of plugs depending on amp ratings, or they're hard wired in.
