Old 10-31-2016, 01:33 PM   #6 (permalink)
California98Civic
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
Great info. Thanks for sharing your research. The standard test for the 02 and the ECU in the Honda FSM is "replace with known good"--as if the FSM assumes you are at a dealership and have ready access to replacement parts or something, lol.
Check connections to the ECU, making sure the tech really hooked it up correctly. Check the O2 as well. I know it was good before, but there are coincidences and maybe something is suddenly registering differently,or has suddenly failed. My OEM starter motor was failing intermittently and I carried around a wrench to tap it everynow and then so it would work normally. Three years ago, I swapped my transmission, and my starter problem went away permanently. Then, suddenly, the slave cylinder on the hydraulic clutch mechanism had a complete failure. Ghosts in the machine do odd things.
