Thread: Sparkle the EP3
Old 11-02-2016, 06:24 PM   #27 (permalink)
compdrag
24 Grom - '24 Honda Grom
90 day: 121.34 mpg (US)
The A/C is clutched so drag is very small. You basically have a belt on a free-spinning pulley. I doubt removing it will show up in your fuel economy above background noise, and the weight savings will be minimal. Still, it might help to make some room under the hood, making other things easier to work on?
I want to remove it due the fact that it's tied to the heating and you can't turn it off when I'm using the defroster setting. Which make no sense to me and when that kicks in you can see the MPGs go down on the UG and can also feel it on the power side of the house.
