Old 11-24-2016, 02:15 PM   #3 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
Variable valve timing is automatic and, generally speaking, improves the efficiency and/or power generation over a broader RPM and load range. It's not something for a driver to take advantage of.
I remember on my Civic hearing about a VTEC "switchover" point--turns out Honda uses extra cam lobes and rocker arms that lock at a certain RPM (or do/did on SOHC engines, at least). Toyota's VVT-i, on the other hand, seems to advance timing by adjusting the camshaft drive of the intake cam. I'm guessing there's no set RPM/load where that happens, but probably a variety of conditions under which it does. So, on a Honda you can stay out of VTEC if you want, but on a Toyota you can't stay out of VVT-i?
UIUC Aerospace Engineering
www.amateuraerodynamics.com
