One of the most useful features I have found is the AC and DC amp clamp on my fluke325.
I don't usually have leads on the fluke325 because I mostly use it as an amp clamp.
DC for measuring battery charging or discharging rate, amp draw for an engine starter, solar panel output, DC welding current measurement, 120v inverter power draw.
AC for measuring mostly how much power the circuits in my breaker box are using, gemerator and inverter out put and AC welding output.
AC amp clamp meters are cheap. DC capable one are a lot more expensive
