Old 12-06-2016, 09:24 PM   #8 (permalink)
oldtamiyaphile
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I'm jealous. I drive a similarly sized van for work, a Chevy Express 2500. It has pleasantly tall gearing but even so I'm struggling to extract more than 18-20mpg out of the 6.0L V8.
That's 1.6 vs 6.0 for you. It's still faster than some hatchbacks and the like so no complaints there. It's also a unibody and FWD so it drives pretty much like a car or smaller SUV. FWD means the load floor is only 24" above the ground, much easier to load and get into the back.
It's not so fair to compare those American full-size vans designed around a full-size truck driveline and their Euro counterparts developed from the ground up with ease of use and efficiency in mind. Even though they're usually smaller on the outside, their loading bay can be quite roomy.
I didn't know it would take so long for a shipment from the UK to reach Australia.
Are you sure it's a 5-ton gross vehicle weight instead of a gross combined weight? Anyway, it's still impressive that a 1.6L engine would do that task.
Load space of my van is 6.0m3 vs 6.7 for an E250. An E250 is 4" longer and about 1" wider.
I looked at the Iveco that's built on a 'full size' truck chassis, but the compromises weren't really worth the slight advantage of RWD. But even those manage 30mpg without issue.
Yup, I meant to write GCM. Renaults even in RHD are French built, not rebadged Vivaros. It took a while because demand exceeded supply.
