Old 12-12-2016, 06:50 PM   #10 (permalink)
19bonestock88
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
Potential fuel saving tip:
The handful of CVT's I've driven that have had a manual mode, I could force earlier "shifts" under light/partial throttle than the computer would otherwise do in automatic mode.
http://ecomodder.com/forum/showthrea...ing-21149.html
(Sounds like that's what you already discovered.)
Basically, I mostly just let the trans do its thing as I surge up to around 35-40mph, then switch to manual mode and upshift to "6th", dropping to around 1250 RPM...
Originally Posted by roosterk0031 View Post
While doing research on similar year Rogues, I found a software update for the 8-10 Rogues on the CVT about a vibration, might be good to see if it's been done if it applies to the Altima as well.
I read on nissanclub about such a vibration, basically the update just forces the engine out of the RPM range in which the vibration occurs(usually below 2k RPM)... I read about an owner taking a 5-6mpg hit after getting the vibration stopped... I'm in favor of just living with the occasional vibration(at parking lots speeds and sometimes around 40mph)
The car really needs a belly pan, even the factory front piece is gone... Averaging about 32mpg according to the cars computer, which isn't bad, but it's way down compared to the Malibu...
My current Ecotec project...
My last Ecotec project...
