Old 12-19-2016, 04:38 PM   #11 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
The way I do it is to atomize my fuel with an injector in each intake runner. Then the valve opens and the piston sucks it in to a very hot cylinder where as its compressed 11 times normal becomes a vapor. Then the spark plug lights it off.
The other way I used to do it on my pickup was by running propane which easily flashes to a vapor without heating.
Why you would want to do it outside of the saftey of the combustion chamber with regular gasoline is a mystery.
The Following User Says Thank You to Hersbird For This Useful Post:
ChazInMT (12-20-2016)
