Old 12-20-2016, 06:10 AM   #69 (permalink)
kurzer
kurzer's Avatar
Knut - '07 Toyota Prius
90 day: 50.9 mpg (US)
Santa - '00 Hyundai Santamo
90 day: 29.07 mpg (US)
the best mod i did to my mx5, was setting the mixture leaner. in open loop the car is so rich, even the power isn´t at its best. inner cooling, i guess.
i opend the black cover at the air flow meter. there is the spring base wich i set now 4 klicks leaner.
Weiterleitungshinweis
now the engine runs at WOT at the richer end of the "optimal" section, at FT or/and high revs it is rich anyway. with no klicks but E60 was WOT lean and FT rich. so using regular gas i tend to give it some more klicks. the middle of "optimal" at WOT maybe...
the best tank ever was 5,84 l/100km, 40,27 mpg with 3 klicks. but its not a commuter car but a track tool. the record was normal backroad driving by my sister. the car is definitly faster than stock, laptimes improved and additional shifts at straigts.
kurzer Gruß
Prius II
Hyundai Santamo
The Following 2 Users Say Thank You to kurzer For This Useful Post:
MetroMPG (12-24-2016), niky (04-19-2017)
