Old 12-20-2016, 08:56 PM   #331 (permalink)
oil pan 4
Since I build DC power supplies as needed...
A generator like that runs close to 250VAC. If rectified the peak voltage would only be about 350 volts.
If the voltage could be turned up to around 277v you would have useable 370v power.
You would also need a big high voltage capacitor to make it more of a constant voltage power source.
Some kind of charge regulation should be used.
I bought mine used with 1 hour on it for $1,100 cash, retail is around $3,000.
Continuous loading should be kept undwr 15kw.
