Old 12-20-2016, 09:57 PM   #32 (permalink)
skyking
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
It is! I have plenty of choices now.
One of the plusses of the new transmission is in gears 1~4. They are all a bit closer together now, which is nice for the shifts while towing. Often you get in a spot where you really have to rap out a gear to make a shift, so closing up that spacing by any amount is welcome.
The jump to OD being greater is not really an issue while towing. I won't use it on a hill, only on the flats or downhill. The OD gears are not as strong and when you run in them, it induces a side loading in the transmission that builds heat and wear. My rule of thumb is no more than 10 PSI of boost in 6th.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
