Old 08-13-2008, 12:20 PM   #2 (permalink)
aerohead
malibu
Yikes! Yeah,changing a couple variables simultaneously makes it really tough to nail down what each modification contributes.You might consider restoring tire pressure to your original specs,redo your test loop,and if all other factors haven't drifted too much,the grille block data should fall out of your log book.The difference will also identify what the pressure did for you.
