Old 12-26-2016, 11:13 AM   #13 (permalink)
benfroggg
Interesting.
The way the frame of the original camper was designed up front makes this very difficult/impractical. The doors of the truck are very close to the box... so no way to extend that area and leave a radius.
I could cut up the original frame/walls up front and make it happen.... but I'm already considerably further fabricated than that....
What I can do, with relative ease, is make a softer edge on the top where it meets the front. Does it have to be a radius? Can it be a shallow angle instead?
I could use something like a pool noodle cut lengthwise and installed on the corners around the cab. Not pretty nor as good as what you're describing. But they are 3" or so in diameter.... and they'd serve the dual purpose of preventing me from hitting my head. I could make them temporary and do some testing too.
