Old 12-28-2016, 04:02 PM   #20 (permalink)
benfroggg
I think I may round over the front of the frame or at least put a 45 on it. The rounded corners on the sides can be done afterward with noodles/coroplast. I realized that where the corner meets the cab is already angled at about 15 degrees in the right direction. So putting the noodle cut in half on the corner will be about even with the existing corner where the door meets. Complicated to type out.... easy to see in photos. So I got one small enough that it can be posted here.
Lemme know what you think.
The Following User Says Thank You to benfroggg For This Useful Post:
chefdave (12-29-2016)
