Old 01-01-2017, 05:21 PM   #15 (permalink)
ThermionicScott
ScanGauge <3
ThermionicScott's Avatar
Originally Posted by gumby79 View Post
Fingie that is what oilpan ment by:
If I remember correctly his plan is to run the 1200w size element @200-600w to keep the surface of the element from getting hot enough to boil/vaporize the oil leaving the solids on the element AKA coking.
Well I looked for the write up . I didn't fid it . OilPan did you pull it . Im referring to the one were you had pic.s of the 1" stainless ntp bung welded to an oil pan....
This one? http://ecomodder.com/forum/showthrea...ter-33500.html
I'm interested in "the rest of the story", too.
Best tank (so far): 32 MPG
