Old 01-07-2017, 09:12 PM   #8 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
The Karen-Mobile - '05 Dodge Magnum SXT
Team Dodge
90 day: 26.72 mpg (US)
Fiat Dakota - '00 Dodge Dakota SLT RWD Quad Cab
90 day: 16.67 mpg (US)
The Red Sled - '01 Dodge Durango SLT 4WD
90 day: 16.96 mpg (US)
Originally Posted by Ardent View Post
That's on my wish list!
I put in some basic stuff that actually idles the CPU when MPGuino is active and is not actually calculating anything or capturing any signal. It should reduce power consumption somewhat.
Originally Posted by sallen View Post
Awesome - sorry probs could've worked that out as I'm using a nano as my arduino.
I still can't set the system time tho.
System time edit bug was due to a faulty re-write of the display code, and has been reverted. Try it now.
Originally Posted by josemapiro View Post
Hi t vago
I've been updating and found that the new version does not allow you to change the number of injectors.
In setting the number changes but then shows the previous number which is 6.
Logic fault was found in the parameter save section, and has been fixed. Try it now.
The Fiat Dakota
The Karen-mobile
The Red Sled
The Following 2 Users Say Thank You to t vago For This Useful Post:
Ardent (01-08-2017), josemapiro (01-08-2017)
