Old 01-08-2017, 07:13 AM   #258 (permalink)
teoman
teoman's Avatar
A3 - '12 Audi A3
Does anyone here know about ecu tuning?
I know you can fiddle with the ignition timing, fuel pressure, injector timing etc... can you also play around with charging voltage? In these applications, it might be advantageous to pump it up to say 15 or 16V (if you are able to fast balance the capacitors). Or change the algorithm of the charges.
