The longest our family was able to stay in 1 spot was 3 months, chasing my seniority. Average was 2weeks ,exception was winter lay off. Layoff at Union Pacific Railroad could be hours- months depending on seniority and availability. A 250ga tank would be nice , however not practical as we had to be able to pick-up and go on a moments notice. So we carried a spair tank that got rotated through. Once a week wasn't so bad to fill the gas during the worst weather, 1-2 month in summer. We went to town for food more often than that. 3 people ÷ small RV fridge =frequent store runns.
How long to plug-in
((W*btu)÷lbs H2O=Delta T per hr) - losses
[Not accounting for thermal loss from lorn block or cooling sys] [not accounting for effect of antifreeze]
1btu= 1°f for 1lbs water
1watt= 3.41btu
1 ga= 8.36lbs
Cummins blockheater=750wh
Late first generation Cummins=4ga coolent
((750*3.41)÷33.44=
76.49°f/hr ) - losses
So 1hr will do ~ 50°f/hr
Engine Block Heater
The engine block heater is a resistance heater installed in the water jacket of the engine just above and behind the oil filter. It requires a 110- to 115-volt AC electrical outlet with a grounded, three-wire extension cord. The engine block heater is required only when ambient temperatures are below -20F (-29C), but recommended at temperatures below 0F (-18C). For full capability, once you turn on the engine block heater, it needs to run for one hour before you start your truck.
Ram Turbo Diesel Cold Weather Tips – Geno's Garage
We know its
helpful at any temperature below operating °f
I'm using my plug 24/7 now (power bill is upsetting) and at 37below 0°f its a hard start. So I'm going this route
http://ecomodder.com/forum/showthrea...ter-34459.html theas are also used a primary Hydronic cabin heater in RVs.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg :
31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
