Old 01-09-2017, 11:09 AM   #18 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by josemapiro View Post
Knowing the first value, this value is not necessary correct.
If I need to, how do I get it?
There are two stored parameters before the "# of cylinders" parameter.
The first is "P(Fuel)" and it can be in either psig *1000 or in Pa. The second is "P(Ref)" and it can also be in either psig *1000 or in Pa.
In the code I have attached at the beginning of this thread, I have both of those values set to 43500 psig * 1000, so that square root portion will evaluate to 1.
P(ref) should remain at 43500 psig * 1000, because that is the pressure that fuel injectors are normally flow-tested at, to get their flow ratings.
P(Fuel) is the fuel pressure of your vehicle, and should be set accordingly.
The Following User Says Thank You to t vago For This Useful Post:
josemapiro (01-09-2017)
