Old 01-10-2017, 07:59 AM   #16 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Well next project is to kind of make a cargo can conversion kit for the Prius to load more items but I've kind of hit a road block. It seems like the HV battery is on top of a hump and really is limiting height of loading bay capacity. Anybody know if the battery has enough slack to where you can move it forward and mount it where the rear seat used to be? Goal is to make a diamond plate loading bay tray and make it as flat with as much usable volume as possible.
Also side note removed a LOT more weight. Really need to go through and weigh items but I'd guess I've removed around 120 pounds. Throw back in an aluminum tray floor, remove the brake dust shields for increased thermal capacity for the brakes and you could have a nice gvwr value with great gas mileage.
ID:	21142   Click image for larger version
ID:	21143   Click image for larger version
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
