Old 01-12-2017, 01:35 PM   #6 (permalink)
Vman455
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
The only time I kept track of fuel economy, my 2002 GTS returned 21.6mpg on an interstate trip from Illinois to Washington. I wasn't a hypermiler then, just driving normally. The T-56 had a very tall 6th gear, keeping engine RPM at ~1900 at 80mph; slowing down a little would probably reap a couple mpg at least, with lower aerodynamic drag , lower RPM, and increased throttle opening. In the truck, with a slightly larger engine (8.3L vs. 8.0) and the same transmission (taller final drive and taller wheels/tires) but horrible aerodynamic efficiency, the difference between 65mph and 80mph was as much as 4mpg.
Somewhere in Wyoming:
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
darcane (01-12-2017)
