Old 01-12-2017, 01:45 PM   #9 (permalink)
Daox
Found a bit more info. Here is a oil temp vs viscosity chart. If the lines are THAT close together at normal operating temperature (~90°C), then at colder temps they are quite a bit more drastic.
Image from: Oil Viscosity Explained
Image from: https://www.quora.com/What-is-the-di...0-5w-30-10w-30
ID:	21160   Click image for larger version
The Following User Says Thank You to Daox For This Useful Post:
ThermionicScott (01-12-2017)
