Old 01-12-2017, 02:29 PM   #12 (permalink)
ThermionicScott
ScanGauge <3
ThermionicScott's Avatar
Found a bit more info. Here is a oil temp vs viscosity chart. If the lines are THAT close together at normal operating temperature (~90°C), then at colder temps they are quite a bit more drastic.
Image from: Oil Viscosity Explained
Stuff like this is why I'm so ga-ga for 0W30 oils these days. Even if we don't often put the low-temperature specs (-35°C, yow) to the test, they'll flow much better after cold-weather starts than 5W_ and 10W_ oils. Just imagine what that chart would look like if extended to include some real cold temperatures.
Best tank (so far): 32 MPG
