Old 01-12-2017, 05:15 PM   #21 (permalink)
josemapiro
Hi t vago
Thanks for the help calculating, I created a file in excel to help in some calculations, if I can check if everything is working well thank you and can make some corrections if necessary.
The file is here.https://mega.nz/#!hZEDnJpQ!hJ1LKufAT...xUxGz6fUnj2lO4
This last version of MPGuino I am not able to upload the code for the arduino, it starts but then it takes a lot of time and in the end it gives an error but does not specify what it is, maybe it is deep sleep before concluding, because it takes a lot of time for later give the error.
Thanks
José Rodrigues
