Old 01-13-2017, 11:14 AM   #20 (permalink)
oil pan 4
You could pressurize the oil with a 12v gear pump. But I don't see any advantage to the expense and complexity involved.
The oil does heat up through the block but it also loses heat through the sheet metal on the oil pan.
