Old 01-13-2017, 02:49 PM   #26 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by josemapiro View Post
Hi t vago
There must be some problem with the code because if I use the version "20170107 - mpguino_1.94_tav.c" it works normally as you can see below, this error only happened in these last two versions.
Can you tell me (or copy and paste into your reply) what all options you selected? I cannot duplicate your problem, either with the 20170107 version or the version I am currently working on. It might be an issue with your Arduino IDE, as I notice you're using 1.8.0 for Windows. I am using version 1.6.12 for Windows and 1.0.5+dfsg2-4 for Linux.
