Old 01-14-2017, 03:03 PM   #219 (permalink)
Daox
The Insight lives!
It turns out that it was a loose connection on the fuse panel. I crimped the connectors to pinch the pin better and it worked great. Here are some images.
Here is the fuse panel. The brown connector was the troublesome one. If I lifted up on it, the instrument cluster would come to life.
So, I pulled the connector and found it was simply a blade style connector. I took a small screw driver and bent the connections a bit tighter and reinstalled it. That seemed to do the trick. I wiggled it around and it stayed on.
ID:	21184   Click image for larger version
The Following 2 Users Say Thank You to Daox For This Useful Post:
Ecky (01-14-2017), ThermionicScott (01-16-2017)
