Hmmm, in my G2 Insight, I taped lower air entrance shut, the upper driver side also has tape.
Air does come in thru left side top radiator grill n also thru from engine bottom area where the lower panel should be but it was lost by the PO.
So far..., all is great !
The ECU thinks temperatures are higher thus leaning out fuel mixtures, I drive quite unemotional n easy so demand for lots of gas is actually little.
After new updated ECU codes installed n temperatures cheating, MPG's have gone from mid 40's to 50+/_ MPG' ��...
Reason: Correction
