Old 02-07-2017, 02:21 AM   #2 (permalink)
Natalya
Engine-Off-Coast
Natalya's Avatar
Red 2000 Insight (2017 through 2019) - '00 Honda Insight 5MT
90 day: 64.72 mpg (US)
Red 2000 Lithium Insight (2020) - '00 Honda Insight LTO
90 day: 71.76 mpg (US)
I love your spirit. It's great to accomplish what people say can't be accomplished.
With hypermiling it's a hundred tiny things eventually adding up to big improvements.
If you're nimble enough to jump inside you can remove the big pipe footstep things to save some weight.
You can also shorten the stalks for the mirrors, or maybe replace them with adjustable stalks so you can have them in close unless towing.
You can probably get partial side skirts installed in the back wheel wells pretty easily.
If you get a ScanGauge II to monitor water temp you can partially block the grill in an aerodynamic fashion. SG can also help with other aspects of hypermiling.
The Following User Says Thank You to Natalya For This Useful Post:
101Volts (03-08-2017)
