Old 02-08-2017, 09:58 AM   #81 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by skybolt View Post
The following is based on:
Code:
const char overFlowStr[] PROGMEM = "999999";
Code:
  reserveQuantity = doCalculate(instantIdx, tFuelEcon); //instant fuel economy
  if (doCalculate(instantIdx, tFuelEcon) > 999999) {
    text::stringOut(devLogSerial, PSTR("999999\",\n")); //infinte fuel economy, good for overflow and reasonable for anything above 999,999 (current overflow is 4,294,967.295 or (2^32)-1), check decimals is 999999 999.999 vs 999999.000?
  } else {
  doOutputNumberJSON(reserveQuantity, 3, PSTR("\",\n")); // instantaneous fuel economy
I modified the formatDecimal() routine a little, to replace the overflow dashes with a string of '9's, if the calling routine specifies this in the procedure call. Now, doOutputJSON() and doOutputDataLog() both use this modification, and everything else still uses dashes.
Code:
  doOutputNumberJSON(2 * doCalculate(tankIdx, tFuelEcon) / 3, 3, PSTR(",")); // 2/3  tank fuel economy
   doOutputNumberJSON(3 * doCalculate(tankIdx, tFuelEcon) / 3, 3, PSTR(",")); //  tank fuel economy, helps user differentiate current trip measure vs tank measure, with goal to keep current measure and instant marker above tank range
   doOutputNumberJSON(5 * doCalculate(tankIdx, tFuelEcon) / 3, 3, PSTR("],\n")); // 5/3 tank fuel economy
  text::stringOut(devLogSerial, PSTR("\"measures\":["));
//  min comparison keeps measure bars from extending past range, even if values in text are shown larger than range
  doOutputNumberJSON(min(doCalculate(currentIdx, tFuelEcon),5 * doCalculate(tankIdx, tFuelEcon) / 3), 3, PSTR(",")); //return lower of current trip mpg or range high bound
  doOutputNumberJSON(min(doCalculate(tankIdx, tFuelEcon),5 * doCalculate(tankIdx, tFuelEcon) / 3), 3, PSTR("],\n")); //return lower of tank mpg or range high bound
  text::stringOut(devLogSerial, PSTR("\"markers\":["));
//min compare keeps white marker from extending past range
  doOutputNumberJSON(min(doCalculate(instantIdx, tFuelEcon),(5 * doCalculate(tankIdx, tFuelEcon)) / 3), 3, PSTR("]\xfd")); //
This certainly works, but the purist in me doesn't like it. min() has to calculate both terms first, then make the comparison. While SWEET64 is much faster now, than when we first tackled doOutputJSON() back in November, it's still kind of a computation hog. Let me chew on this a bit - I might come up with a SWEET64 solution that does this thing.
