Old 02-14-2017, 08:28 PM   #8 (permalink)
EricDeLee
Originally Posted by dfeldt91 View Post
Has anyone ever hooked up an extra(or replaced) battery that you could charge at home to avoid charging the battery via engine power to get higher MPG?
Haven't done the extra battery thing; but I think a few have thought about that in the past. But something to consider: one of the IMAC&C that are sold with a joystick. With the current programming; I could run the IMA assist for 30 mins straight, then allow the IMA to recharge through normal driving/regent braking and do it again. I could run two+ cycles like this on my trip to work; and then another two+ cycles on the way home (all freeway driving). In my CVT I was getting 60-72 mpg for my trips. Mostly around 64-65 mpg over a month or so.
I'm assuming you can do better with an MT, and lean burn.
