Old 02-17-2017, 02:05 PM   #97 (permalink)
gumby79
gumby79's Avatar
little jona - '91 Dodge D 250 first gen cummins LE
Team Streamliner
90 day: 23.4 mpg (US)
Little Jona airo modded - '91 Dodge RAM 3/4 TON D 250 2×4 AUTO
Pickups
The Salted Hound Jenny. - '87 Dodge Ram 50/D-50 5sp 4X4
90 day: 20.24 mpg (US)
Jona Allison aero - '91 Dodge Ram D-250 Le
90 day: 20.76 mpg (US)
That's pretty amazing. Do you have any theory as to why everyone doesn't do it?
Lasy, uninformed, people would just put free tap water in . Thinking it's water, all water is the same tap is just free , why should I have to buy "special water" the Manufacturer is just trying to make a buck. Thinking I have put tap in my radiator all my life with no problems, not realizing that they have been replacing radiators evry 5-10 years Insted of every 40-60 years. Same thing gos for HHO . You can see this with the DEF people are trying everything they can to bypass the systems. Sighting I allerady have to buy diesel why did they add a gimmick forcing me to buy the blue Juice.
In Las Vegas Nevada my sister is recommended to replace(not flush thats every1-2) the raidator every 5-7 years by many shops, because the tap water is plugging the core with Alkali precipitate. They just call it plugged. .
craysus
Also obviously if you tune for water and the system fails or you run out of water it's not good.... But similarly running out of diesel ain't such a good idea either..
Add a floatto the resavor that signals the computer to switch maps and shut down the injection system.
Shepherd777
Modern diesel engines are hyper fuel efficient, with astronomical fuel rail pressures, and a multitude of other internal improvements.
Agreeda CR Cummins with a 1-3000lbs weight penalty gets the same MPG as as my aero modded 12V 6BT 5.9-160 mechanical injected Cummins, but there is room for more
Keep up the good work . .
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
The Following User Says Thank You to gumby79 For This Useful Post:
craysus (02-18-2017)
