Old 02-18-2017, 08:04 PM   #9 (permalink)
Hersbird
Dark Egg - '12 VW Touraeg
I got an above 50% set (8000 miles supposedly) of 275/70/18's mounted and balanced off a 2016 for $290 so that will be my first change. I am going to go as is for awhile and try and get more baseline. See if I can get my torque app dialed in as it is way off for some reason on this motor. Maybe even try an A-B-A test or at the minimum an A-B test on the same day, same course. Use GPS speed as the speedometer will be off.
