Old 02-22-2017, 12:46 PM   #66 (permalink)
Erasmo
Two weels Zero sparkplugs
Originally Posted by RedDevil View Post
You may tilt the handlebar backwards a bit, or maybe even get a different one.
I altered the handlebars on my bikes when I put windscreens on as the lack of pressure made me lean on the handles too much.
The handlebars of a DS are pretty straight so turning them back won't do that much, also I like the current angle. Removing a small strip of about a centimetre in that area also should do the job.
Did a test sit yesterday and applied the aero tool to it.
I'm not sure if it works the same on bikes and if I applied it correctly but it seems that the flow will improve somewhat, hopefully enough to offset the extra frontal area that the fairing introduced.
The Following User Says Thank You to Erasmo For This Useful Post:
briantrice (02-28-2017)
