Old 03-01-2017, 07:46 AM   #47 (permalink)
aardvarcus
aardvarcus's Avatar
Deep Blue - '94 GMC Suburban K2500 SLE
90 day: 23.75 mpg (US)
Griffin (T4R) - '99 Toyota 4Runner SR5
90 day: 25.43 mpg (US)
With the Suburban back outside, I turned my attention to cleaning up the engine bay a bit and continuing to disassemble parts as needed. I removed the firewall insulation, as I will be replacing it with new.
On the inside, I started to pull the interior out, thinking I would just remove the seats to be able to deep clean the carpet. Then I pulled the trim so that I could clean all the way to the edges. Then I remembered I need to peel the carpet up so that I can cut the hole in the floor for the stick shift. Before long I just kept pulling parts off so I am down to bare sheet metal for most of the interior. The pictures were in progress shots, so there is more pulled than shows. I still need to pull the dash and headliner.
ID:	21336   Click image for larger version
ID:	21337   Click image for larger version
ID:	21338   Click image for larger version
The Following 2 Users Say Thank You to aardvarcus For This Useful Post:
deejaaa (03-01-2017), slowmover (03-09-2017)
